2001 Chevy S-10 Speedometer Stuck
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOHAVEB
I recently replaced my battery in my S10 pick up and noticed when I got in that the speedo is pegged at 100 MPH. It stays in the same place with the ignition on or off. I disconnected the battery and reconnected with no results. Thanks for the help!!
Dec 29, 2009 at 8:28 AM
KHLOW2008
  • 41,812 POSTS
Hi mohaveb,
Thank you for the donation.
Power surge during installation of the battery has caused the needle to overshoot.
Remove the meter cluster and manually turn the needle back to zero and retest.
Dec 31, 2009 at 2:37 AM
