2001 Chevy S-10 P0410 Code
109,000 MILES • 6 CYL • 2WD • MANUAL
BRMYKM
CODE P0410 - When this code came up, I had a new air pump, fuse and relay switch put on, but the sevice-engine light continues to come . Also, when I run the AC, the water never drips out!
Apr 20, 2010 at 10:32 AM
HMAC300
  • 48,601 POSTS
you may have had an air pump puton but is the valve any good so it gets to the exasut sytem. they will need to check it out. the water not coming out , there is ahose under the truck by the bottom of the firewall. crawl under there and stick like a coat hanger up it to clean it out, it's probably clogged......
Apr 22, 2010 at 12:20 PM
