2001 Chevy S-10 oil pressure
WCPEACOCK
  • 2001 CHEVROLET S-10
2001 Chevy S-10 4 cyl
when I crank my engine while it is cool the oil pressure runs about 30 after it warms up it runs about 20-25 any ideas to what may be the cause and how to fix.
Saturday, April 25th, 2009 AT 7:54 PM
While engine is warm and idling should be about 8-15psi and the faster the engine spins should go higher. If in doubt do an oil pressure check if normal replace the oil pressure switch abnormal could mean the oil pump and engine bearings.
Saturday, April 25th, 2009 AT 8:24 PM
