1991 Chevy S-10 REMANUFACTURED MOTOR RUNNING HOT
EWIGGINS
  • 1991 CHEVROLET S-10
Engine Cooling problem
1991 Chevy S-10 6 cyl Two Wheel Drive Automatic 0
I just put a remanufactured motor in my truck and it runs hot. Has a new water pump, tried two thermostats, and is full of fluid. What could be wrong?
Monday, October 20th, 2008 AT 6:00 AM
SWILLIAMS
  • 597 POSTS
What are you calling hot? Normal temperatures run in the 198-210.
Where did the rebuild come from?
What condition is the radiator in?
What is the oil pressure and how does it run overall?
It could be simply that the engine was built tight and will need to break in some. How long does it run until it heats up?
Monday, October 20th, 2008 AT 2:12 PM
EWIGGINS
260 and the check gage light comes on
carolina machines
it runs sweet just got the motor put in saturday
it will run ten minutes then the light comes on
Monday, October 20th, 2008 AT 2:17 PM
SWILLIAMS
  • 597 POSTS
10 minutes to 260 is WAY fast. Is this the original radiator? Was it in good shape? Any bubbles in the overflow? I would probably run a pressure test on it to see what you get.
Monday, October 20th, 2008 AT 3:45 PM
