2001 Chevy S-10 no gas getting into the motor
1BDCAMARO
Engine Mechanical problem
2001 Chevy S-10 6 cyl Two Wheel Drive Automatic 125xxx miles
ok well 1st its not a s-10 its a sonoma but their are more people looking at the s-10 stuff but my problem is that i have 54psi of fuel at the back of the motor it just wont make it into the motor a have already changed all of the sensors on the top of the motor and even thr cam sensor in the dis with no luck i can put gas in a bottle and put it in the top of the motor and it starts right up can someone help
Jun 9, 2010 at 5:35 AM
  • 75,988 POSTS
Your fuel pressure is low the specs is 60-66 psi
Jun 9, 2010 at 5:45 AM
1BDCAMARO
ok thank you did not want to hear that but ok i will change it
Jun 9, 2010 at 6:00 AM
