Sir-You need to have the computer scanned for OBD2code/s the computer has identified a problem within the engine management system.
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
SPONSORED LINKS
Wednesday, February 11th, 2009 AT 11:51 PM
