2001 Chevy S-10 light problem
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
BARTRAN1975
About a month ago the low beam lights quit working. Now I have no brake, signal, or low beam lights. When I try to select the low beam lights, the fog lights work as they should. The lights in the instrument cluster will go dim sometimes when the truck is shifted into or out of park. High beam, parking,interior and fog lights work well
Jun 12, 2010 at 11:48 AM
HMAC300
  • 48,601 POSTS
chekc your headlight bulbs. the low sides can burn out an d the high beam still work. also check to see if there is a relay underhood it may have gone bad and check your fuses...
Jun 15, 2010 at 12:37 PM
