2001 Chevy S-10 Heater Fan Noise
50,000 MILES • 4 CYL • 2WD • MANUAL
VJ7505
On and off for several years the heater/air cond fan would make a noise - if I cracked open the window or lower the fan speed it would stop. Now however at any speed -with or without the window being cracked open the noise continues. More so at higher fan speeds. There is still heat and cooling coming out. The noise sounds a bit muffeled and louder as the speed increases.
Nov 16, 2009 at 4:57 PM
BMRFIXIT
  • 19,053 POSTS
I would remove blower motor and inspect fan blade and motor bearing
replace as needed
Nov 17, 2009 at 11:37 AM
