2001 Chevy S-10 fuel tank pressure sensor circuit low volta
124,448 MILES • 6 CYL • FWD • AUTOMATIC
SWEEPER2180
hello i will like to know please where is located this sensor P0452 fuel tank pressure sensor circuit low voltage and where can i find it in the truck please if you know how this sensor is located
Jul 9, 2010 at 2:33 PM
HMAC300
  • 48,601 POSTS
i's on top of the fuel tank. but make sure you have 5 volts going to it on letter "c" with the connector disconnected and ignition switch turned on. I fyou replace the sensor take the box off it's alot easier...
Jul 13, 2010 at 1:23 PM
