2001 Chevy S-10 fuel injector
2001 CHEVROLET S-10
70,240 MILES • 4 CYL • 2WD • AUTOMATIC
TSLOWLOWREGAL
  • 6 POSTS
hello I have been having this problem with my truck for a few months now, I had the engine worked on and when I got it back the mechanic told me that my # 2 injector is not working properly so I drove of like that but then the truck started running real ruff, I noticed that when I would mess with the connector on top of the injector the truck would run perfect so I thought that maybe the connector would be the problem, I then went to a local junk yard and got one but it still did the same thing, they told me that more than likely it’s the injector it self but I don’t under stand why is it that when I move the connector on top it runs good?
Feb 18, 2009 at 5:45 AM
Turn key to run and check for power at both injector or hook a noid lite to the injector harness connector and crank engine over it should be pulsing. Also might want to check the injector's resistances.
Feb 18, 2009 at 6:28 AM
TSLOWLOWREGAL
  • 6 POSTS
I did the test light and there is power at the harness,
do you think it might be the injector it self then?
it just seams weird that when I move the harness around it runs good and when I stop it don’t its kind of like if theirs a wire or something not making good contact
Feb 19, 2009 at 3:53 AM
Test the injectors resistances both or just replace it
Feb 19, 2009 at 7:07 AM
TSLOWLOWREGAL
  • 6 POSTS
i just replaced the injector and the truck is still doing the same thing, like i said befor the weird part is that when i move the conector it works good.
please help
Mar 13, 2009 at 9:02 AM
when i move the conector it works good. Check the connector could be a break in the wire do a continuity check between the injector connector and computer harness connector.
Mar 13, 2009 at 10:53 AM
SHTKICKER01
  • 7 POSTS
i had a same problem like that on my oldsmobile with my 3rd cylinder injector. I went to a junk yard and just got a the connector its self and wired it in and it seemed to fix mine i havent had a problem just cut off the connector and splice it in and try that.
Mar 15, 2009 at 2:21 PM
TSLOWLOWREGAL
  • 6 POSTS
thanks all i just replaced the whole injector harness and that fixed it 180$ after i got, thanks all
Apr 1, 2009 at 4:51 AM
