2001 Chevy S-10 Fixing Four wheel drive
106,666 MILES • 6 CYL • 4WD • AUTOMATIC
BNSF
I have a Chevys10 and i got stuck one time and try to turn the four wheel drive on to get stuck and did not came one and i think it broken. i like to fix the problem myself without sending it to a repair shop and spending five hundred dollars that they saying it needs to be replace, and i check the fuse and its good and check the connections to the buttons and is connected but the light is not lighting up.
can you please help me what is the problem.
Mar 4, 2010 at 7:23 AM
  • 110,248 POSTS
Have you checked for power to the actuator on the transfer case?
Mar 8, 2010 at 4:11 PM
BNSF
Yes i did and check the fuses and the cord everything checks fine. It just don't want to come on.
Mar 9, 2010 at 5:10 AM
  • 110,248 POSTS
If you have power to the actuator and it isn't engaging, the actuator must be bad. Remove it and have it checked.
Let me know what you find.
oe
Mar 9, 2010 at 1:24 PM
