2001 Chevy S-10 fan clutch removal
TBACHMEIER
Engine Cooling problem
2001 Chevy S-10 4 cyl Two Wheel Drive Automatic
how to remove fan clutch that is not attached to the waterpump,and is held by 1 large nut. i am unable to restrain the nut with belt
Mar 24, 2010 at 6:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have to use 2 fan clutch wrenches to remove the fan and clutch assembly then remove the fan from clutch, its normal threads (left to loosen).
Mar 24, 2010 at 7:02 AM
TBACHMEIER
where do you use second fanclutch wrench
Mar 24, 2010 at 8:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
can also go another way, you have 4 bolts that hold the fan and pulley bell to the water pump and in the center of all that, you have a big inch and a quarter hex that holds the clutch fan. Remove 2 of the 4 bolts. Replace them with 2 and a half inch bolts the same thread. Hold a pry bar between the 2 long bolts and crank the hex off
https://images.2carpros.com/forum/automotive_pictures/261618_62217_Blades_1_1.jpg
Mar 25, 2010 at 7:24 AM
