2001 Chevy S-10 electronic control module
JEFFSNTN
Electrical problem
2001 Chevy S-10 4 cyl Two Wheel Drive Automatic
i keep blowing fuses only happened every once in a while would just change fuse and off i go, today changed fuse and just kept blowing out. do i need a new ecm
Jun 16, 2009 at 1:38 AM
JDL
  • 16,098 POSTS
Hello, not sure which ecm fuse your talking about? the ecm B fuse is battery voltage, hot all the time, serves ecm and fuel pump relay.
Ecm 1 fuse goes hot when you turn on the key, serves several circuits. I'd suspect one of the other circuits before the ecm.
Jun 16, 2009 at 3:12 AM
