2001 Chevy S-10 DIAGNOSTIC CODE
ERHUNT3
Computer problem
2001 Chevy S-10 6 cyl Four Wheel Drive Automatic
I HAVE A DIAGNOSTIC CODE (PO128) AND NOBODY CAN TELL ME WHAT THIS CODE MEANS.I HAVE BOUGHT A HAYNES MANUAL WHICH LIST A BUNCH OF CODES BUT NOT THIS PARTICULAR ONE.DOES ANYONE KNOW? I AM NOT RICH AND TRYING TO AVOID TAKING MY TRUCK TO A REPAIR SHOP.
Mar 23, 2010 at 12:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P0128 : Engine Coolant Temperature Exceeds Lenght of Time To Reach Preset Temperature
Check coolant level, top off if needed and reset code. If coolant is full, suspect faulty engine coolant temperature (ECT) sensor or bad wiring to sensor.
Mar 23, 2010 at 4:20 PM
AUTOTECHCHICK
  • 8 POSTS
This codes stands for "coolant temperature below thermostat regulating temperature". It is set when the desired engine operating temperature is not reached in a sufficient amount of time. The powertrain control module (PCM) monitors the engine coolant temperature (ECT) to determine when this has occurred. Common causes for this code include incorrect coolant level, a failed ECT or a stuck thermostat. For more information on this code,
May 12, 2016 at 1:16 AM
AUTOTECHCHICK
  • 8 POSTS
