2001 Chevy S-10 daytime running light
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
JUANPENA
my driver side drl is not working. I replaced the bulb and still no change. The brights work. What would cause this? Is there a relay that I should replace or is it more a grounding issue? Juan
Dec 20, 2008 at 2:15 AM
MIKE H R
  • 3,094 POSTS
heck the socket that you have power going to the light. If you don't have power Check the fuses for the headlights. And clean then check the ground.
Dec 27, 2008 at 1:41 AM
