2001 Chevy S-10 Check Engine light
CHEVYS1012345
Electrical problem
2001 Chevy S-10 Manual 43000 miles
Took the truck to a trusted mechanic, and after diagnostic, told me nothing wrong with vehicle except the fuel sensor. However, I am told that while the sensor is relatively cheap, less than 100 bucks, the labor may be 500-700 dollars, as that is very extensivework m also told I cannot pass inspection if this problem is not fixed. Being unemployed for 10 months, that kind of $ is hell to pay out for a damned sensor. I should also mention they reset the sensor, and told me to drive on it, and now sometimes the Engine light comes on, sometimes it is off. But no troubles with the vehicle otherwise. Anyone help me with a simple solution? Or will I just have to bite the bullet and pay up on this? Thank you.
Dec 30, 2009 at 9:41 AM
MERLIN2021
  • 17,250 POSTS
Can you narrow it down to which of the three you need help with? What was the exact code?
https://images.2carpros.com/forum/automotive_pictures/62217_fuel_Sensors_1.jpg
Dec 30, 2009 at 10:19 AM
CHEVYS1012345
the code is P0178
It is the Flex fuel sensor.
Dec 30, 2009 at 11:16 AM
MERLIN2021
  • 17,250 POSTS
This is on the top right of transmission, if you cant get at it, use a floor jack jack tranny slightly, remove the tranny mount at tailshaft, lower tranny, this might get you enough room...
Dec 30, 2009 at 6:57 PM
