2001 Chevy S-10 brake lights
2001 CHEVROLET S-10
12,100 MILES • 6 CYL • 2WD • AUTOMATIC
CARTURO
drivers side brake light wasnt working, so i change all the bulbs on that one side, it still doesnt work and when i brake, the white reverse warning white lights come on both sides, do you think that maybe the i need to check the fuse box inside the truck and change them or could it be a loose wire
Nov 25, 2009 at 12:03 PM
JDL
  • 16,098 POSTS
Hi, when you changed the bulb, did you use a testlite in the bulb socket, to check for voltage, key on, left turn on? Yellow wire carries voltage for left turn. There shows to be a left turn fuse, underhood fuse block. Not only check the fuse, use a testlite on the fuse circuit to see if the circuit is hot. Key on left turn activated.
Nov 26, 2009 at 4:18 AM
