2001 Chevy S-10 abs/brakes stays on
RODELIO SARNO
Brakes problem
2001 Chevy S-10 6 cyl Two Wheel Drive Automatic
already change the back and front brakes and the abs/brake lights still stays on and sometimes goes off
Jul 28, 2010 at 9:47 AM
HMAC300
  • 48,601 POSTS
have the truck scanned to see why the abs light is on, you may have a bad sensor or wire and unless the truck is scanned youdon't know what is wrong.
Jul 29, 2010 at 1:32 PM
ANGEL ROSADO
I HAVE A 2002 S10, ABS AND BRAKE LIGHT STAY ON. IF I DON'T USED THE TRUCK FOR 1 OR 2 DAYS THE LIGHTS STAY OFF FOR SHORT TIME, AND THEY COME ON.I TEST WITH COMPUTER THE FOLLOWING CODES:C0265 EBCM RELAY CIRCUIT,CO242,C0245,C0246,C0251,C0252 EBCM INTEINAL SOLENOID OF CONTROL VALVE CIRCUIT AND C0241 PCM INICATED REGUESTED TORQUE FAULT. WHICH SOLENOID IS THE BAD ONE OR HOW DO I CHECKED.
Feb 15, 2012 at 5:31 PM
