why does my abs light and parking break light come on together. Thanks Vic
Jul 2, 2008 at 4:07 AM
SWILLIAMS
✓Experienced Mechanic
Check for a leaking brake line or caliper or wheel cylinder. The brake light come on to tell you there is a mechanical fault in the system. The ABS light is on because of the failure as well. You will need to repair the leak and bleed the brake system.
