2000 Chevy S-10 When should timing belt be changed
MTJEROGERS
Engine Mechanical problem
2000 Chevy S-10 4 cyl Two Wheel Drive 113,00 miles
Just purchased a used S10 with 113,000 miles on it, the timing belt has not been done, when should it have been done?
Aug 22, 2010 at 7:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your S-10 uses a timing chain, not a belt. there is no set interval to replace timing chains because they are meant to last the life of the engine.
Aug 22, 2010 at 8:29 AM
