2000 Chevy S-10 trying to figure out some prices
VINNIE GAZZANO
Engine Mechanical problem
2000 Chevy S-10 6 cyl Two Wheel Drive Automatic
how much will it cost for 2 oxygen sensors, and the laber to get them put in??
Oct 12, 2010 at 4:54 AM
WRENCHTECH
  • 20,760 POSTS
Why would you need 2 oxygen sensors? Did someone tell you that?
Oct 12, 2010 at 5:05 AM
VINNIE GAZZANO
when i went to get a smog check they gave me a piece of paper that said :
Electronic Control unit ID:10
System too Lean: Bank 1 (P0171)
System too Lean: Bank 2 (P0174)
Random/ Multiple Cylinder Misfire Detected: (P0300)
..-i changed my spark plugs already-..
Oct 12, 2010 at 5:50 AM
WRENCHTECH
  • 20,760 POSTS
Those codes don't mean bad sensors. They mean the system is running too lean for some reason and someone needs to find the reason. Vacuum leaks are the most common cause.
Oct 12, 2010 at 5:52 AM
VINNIE GAZZANO
how do i find out the problem?
Oct 12, 2010 at 6:07 AM
