2000 Chevy S-10 Troubleshooting
142,000 MILES • 4 CYL • 2WD • MANUAL
GILBERT65
Recently change high pressure hose due to leakage and leakage on one of the two charging inlet-valves.All fixed charged with fluid (R134A),worked good as new for about 30 minutes or while driving a mile,suddenly stopped cooling.I noticed a blownout fuse (15 amps) in relay panel ;after I replace it, it will blowout again.Cooling system worked perfectly before and after replacing hose for a while.
Apr 13, 2010 at 7:18 AM
MERLIN2021
  • 17,250 POSTS
Post what fuse blew, and which panel? Under hood or under dash...bit it sounds like the a/c clutch coil fuse?
Apr 13, 2010 at 7:23 AM
