2000 Chevy S-10 timing chain replacement
170,000 MILES • 4 CYL • 2WD • MANUAL
DPANCHOT
I'm trying to replace a timing chain on a 2.2 liter engine. My problem is I can't seem to get the cooling fan and clutch assy off. I removed the belt and 4 bolts on the pulley. the pulley is loose but the fan is not. It seems to be attached by a 1.5 inch wide hex nut that spins on a bearing. Any sugestiions? Also I need to know if a 2.2 liter s10 engine is a interferance engine. I'm wondering if I might have bent valves because the chain is broken.
Jun 4, 2009 at 4:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will need a special service tool (SST) for this repair. First, remove the upper fan shroud. Then remove the fan clutch assembly in a counterclockwise direction using a fan clutch wrench (this is the SST). Remove the fan clutch assembly from the vehicle. Remove the fan blade mounting bolts. Remove the fan blade from the fan clutch.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528024da18_1.jpg
I believe the '97 and up models are non-interference engines. A quick call to local Chevy dealer can confirm this.
Jun 4, 2009 at 4:50 PM
