2000 Chevy S-10 starting when humid
FISHBOM
Electrical problem
2000 Chevy S-10 6 cyl Four Wheel Drive Automatic
my truck will not fire when its moist out the engine turns over but will there is no spark sometime after i stop turning it over it kinda spudders its only when its wet out
Dec 28, 2008 at 11:59 AM
MIKE H R
  • 3,094 POSTS
check at night when its wet out. Turn vehicle over to start under the hood where its dark check to see if you can see anywhere it shorts out. Sometimes you will see small sparks where it grounds out.
Dec 30, 2008 at 12:08 AM
