2000 Chevy S-10 shudder and stall
2000 CHEVROLET S-10
104,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAD_INSP44
my vehicle will start to miss and lose power after it warms up. with out warning it begins to spit and sputter backfiring through throttle body when you begin to acclerate it will idle fine.
May 26, 2008 at 12:22 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
change the spark plugs and wires if they havent ben replaced yet or recently.
also have the coil tested and the ignition control module tested.
If you let the vehicle idle till its warm then take off does it still have the problem or does it have to be driven a certain amount before it gets bad.
if the vehicle is turned off and restarted does it run good or does it have to cool down?
May 26, 2008 at 3:15 PM
