2000 Chevy S-10 Replacement of serpentine belt
2000 CHEVROLET S-10
57,652 MILES • 6 CYL • 4WD • AUTOMATIC
EDDIVINE
How do I remove the belt? Must I use a special tool to loosen the tension?
Jan 24, 2009 at 3:27 AM
ISHEE77
  • 20 POSTS
there is a tensioner pulley that keep tension in the belt. with a 1/2 inch drive ratchet, there will be a square hole on the pulley, rotate that pulley and the tension will remove from the belt. you can also use a cro-bar to move the pulley in the direction it needs to go.
Jan 29, 2009 at 5:21 PM
