2000 Chevy S-10 Problems with starting and with clutch
146,428 MILES • 4 CYL • 2WD • MANUAL
LORDJADAMS
I have two problems and I suspect they are related, but I'm not sure.
My first problem is starting the vehicle, but it only happens occasionally.
When I get in and turn the key nothing happens, it acts as if I don't have the clutch depressed. I've had battery problems before, and I know this is different. When it was the battery it would make a clicking noise, or all the lights would go out; but this time it just acts like I'm not turning the key at all, it simply doesn't respond. However, if I just keep turning the key over and over, it will eventually start; it may take two turns, it may take twenty.
My second problem is with the clutch. It doesn't want to "grab" or whatever. I can let off the clutch pedal completely and it still acts as if it's in neutral. As with the first problem, it only happens on occasion. It seems to happen most often when taking off in cold weather, mud or snow.
I'm obviously going to take it to a shop soon, but I'd like to get some input on it first.
Thanks in advance!
Jan 31, 2010 at 6:53 AM
  • 75,988 POSTS
Problem 1
Could be one of the following-starter, starter relay, clutch switch and ignition switch
Problem 2
You clutch is slipping-time for a new clutch assy
Jan 31, 2010 at 6:59 AM
