2000 Chevy S-10 pcv valve replacement
2000 CHEVROLET S-10
95,000 MILES • 4 CYL • 2WD • MANUAL
MIKEREV
the pcv valve does not want to come out of the valve cover. i could probably force it with some vice grip pliers. is that normal? the purolator PV900 and ac delco cv900c do not match what i can see of the original. the origanal hose end is bigger and the part that goes in the valve cover has a smaller diameter than the purolator and ac delco replacements.
Apr 26, 2008 at 4:05 PM
BLACKOP555
  • 10,386 POSTS
you sure thats the PCV valve?
they should come out with a little bit of pressure, usually no more then hand strength.
Apr 26, 2008 at 8:05 PM
