2000 Chevy S-10 overhaul
DAVID P.
Engine Mechanical problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic
HI, before i was laidoff of work,i overhauled my s10 engine. I have fuel presure, pump works.I have spark to all plugs. noid light indicates power to ingectors. timing chian installed correctly.all sensor wires hooked up.oil presure ok. Start engine,engine starts but dies. need some help here.please. I dont have the funds to be sinking in this project,but need truck for family
Jan 30, 2009 at 8:04 AM
MASTERTECHTIM
  • 4,750 POSTS
does the theft light on dash flash when it stalls when key is on?
Jan 30, 2009 at 11:13 AM
DAVID P.
Yes sir the security light flashes right after engine stalls. thank you mr.mastertectim ,me and my family really need help. may god bless you.
Jan 31, 2009 at 1:20 AM
MASTERTECHTIM
  • 4,750 POSTS
yo have a theft problem and we can fix it. first of all you need the battery fully charged. start vehicle and leave key in the run position. the theft light will flash for 10 minutes then it will go out. when it goes out turn key off then start truck and it will start. the theft system lost memory of the ignition cylinder and this is how you program it. hope this helps
Jan 31, 2009 at 4:51 AM
