2000 Chevy S-10 Oil Pan Gasket
JONES1219
  • 2000 CHEVROLET S-10
  • 4 CYL
  • 96,000 MILES
I was wondering if you could give me instructions on changing the oil pan gasket
Saturday, January 31st, 2009 AT 8:13 PM
BRIAN 1
  • 1,030 POSTS
Your not gonna like the answer, here is the instructions:Remove the engine from the vehicle. Refer to Engine Replacement.
Install the engine on a suitable engine stand.
Remove the oil pan. Refer to Oil Pan Removal
Clean the sealing surfaces and the oil pan. Refer to Oil Pan Cleaning and Inspection.
Installation Procedure
Install the oil pan. Refer to Oil Pan Installation.
Remove the engine from the engine stand.
Install the engine into the vehicle. Refer to Engine Replacement. I've done a couple, these SUCK to do. Good luck post back with any other questions.
Saturday, January 31st, 2009 AT 8:19 PM
