2000 Chevy S-10 obd ii codes
172,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARCANRAZORBACK
I have 2 codes shown on my reader P0175, P0300 and not sure what it can be causuing these errors?
Jul 3, 2010 at 8:27 AM
  • 75,988 POSTS
A code P0175 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled
There could be a vacuum leak.
There could be a fuel pressure or delivery problem
Possible SolutionsPossible solutions include:
Inspect all vacuum and PCV hoses, replace if necessary
Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect fuel lines for cracks, leaks, or pinches
Check the fuel pressure at the fuel rail
Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
P0300 normally caused by vacuum leaks and bad fuel
Jul 3, 2010 at 10:43 AM
