Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Electrical
Ignition Switch
Key
2000 Chevy S-10 no response when I turn key
2000 CHEVROLET S-10
195,000 MILES • 4 CYL • 2WD • AUTOMATIC
TAMMY WHITE
MEMBER
1 POST
Is this a fuse or relay problem
Jul 20, 2010 at 4:08 AM
PAPAROACH
MEMBER
Could be starter or neutral safety switch. Check voltage to ignition wire on starter. If 12 volts then it could be the starter is bad. If you don't have 12 volts then it may be the neutral safety switch.
Aug 11, 2010 at 8:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
