2000 Chevy S-10 no response when I turn key
2000 CHEVROLET S-10
195,000 MILES • 4 CYL • 2WD • AUTOMATIC
TAMMY WHITE
Is this a fuse or relay problem
Jul 20, 2010 at 4:08 AM
PAPAROACH
Could be starter or neutral safety switch. Check voltage to ignition wire on starter. If 12 volts then it could be the starter is bad. If you don't have 12 volts then it may be the neutral safety switch.
Aug 11, 2010 at 8:12 AM
