2000 Chevy S-10 no power
OLD MECHANIC53
Engine Performance problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic
The engine in my truck has lost all power to even pull itself. We have checked compression, changed fuel filter, fuel regulator, fuel pump, plugs, plug wires, coils, muffler, cat. converter, air filter. Engine has only 70,000 on rebuild any help would be appreciated.
Oct 25, 2009 at 12:55 PM
  • 110,248 POSTS
How did you check the converter? Did you check back pressure? Also, how much fuel pressure did the vehicle have, and did the check engine light come on? Finally, what was the compression and did you check timing?
Nov 12, 2009 at 5:41 AM
