2000 Chevy S-10 Missing Bad
2000 CHEVROLET S-10
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
SNAP_KNIGHT
I recently started getting bad gas mileage and I then changed the spark plugs and the air cleaner. I was still getting bad gas mileage, so I used some Chemtool injector cleaner to see if my injectors were clogged.
Shortly after that, the engine began missing...a little at first and now terribly. I then changed the fuel filter (california emissions style) and there is no change. The check engine light did, however, come on when it started missing really bad.
What do you think?
Aug 21, 2008 at 9:50 PM
MASTERTECHTIM
  • 4,750 POSTS
first step is have the computer scanned for coeds. autozone does it for free, this will tell us what sylinder is misfiring. its possible you have a bad coil or plug wire, thats the most common problem
Aug 21, 2008 at 10:44 PM
