2000 Chevy S-10 hesitation
FRNKNDNGL
  • 2000 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 173,494 MILES
I am having problem when taking off I replaced the fuel pump, filter, wires, coil, cap, roder, pulloff, also I did a compressing test all about 160psi did a fuel test but when I turn off the key I loss a pressure a in the fuel.
Saturday, July 18th, 2009 AT 4:50 PM
When the pump is turned off or stops running, the system should hold residual pressure for several minutes (look up the specs to see how much pressure drop is allowed over a given period of time). If pressure drops quickly, the vehicle may have a leaky fuel line, a leaky fuel pump check valve, a leaky fuel pressure regulator or one or more leaky fuel injectors. Low residual fuel pressure can cause hard starting and vapor lock during hot weather.
Possible causes for hesitation:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Saturday, July 18th, 2009 AT 4:57 PM
