2000 Chevy S-10 heater control
79,500 MILES • 6 CYL • 4WD • AUTOMATIC
CHILLY252
I have heat, but the deflector does not go to the floor. Instead it goes to the defrosters. I've already changed the heater control assy(panel), it still does not work. I have panel, defrost with hot or cold. I cannot find a vacuum diagram. Could the plastic divert-er valve be broken or a defective vacuum line or cycl ? please help. thanks
Mar 9, 2008 at 5:24 AM
MASTERTECHTIM
  • 4,750 POSTS
does it go only to defrost? will the air come out any other area? when you switch from defrost to vent is it switching or is it qalways coming out the same spots?
Mar 9, 2008 at 6:40 AM
2CARPRO JACK
  • 11,533 POSTS
Check the vacuum source off the engine. Black plastic line that goes through the firewall to the rotator valve and to the engine on the other side.Defrost position is default for no vacuum present at the selector (rotator)valve
Mar 10, 2008 at 1:01 AM
CHILLY252
yes, when I switch I have air coming out of there, and temperture control. so I believe I do have vacuum off the engine, and I also have defrost.
Mar 10, 2008 at 9:00 AM
