2000 Chevy S-10 Fuel Pump
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
TDOG
I replaced a working fuel pump because it was not showing the correct amount of fuel in the tank. When I turned the key to check the new pump before I set the bed of the truck back in place it wouldn't come on. I checked the GREY wire and it is getting power. I exchange the fuel pump just to be safe and the new one does not work either. I then plugged the old pump that I know works and still got nothing. I then took the BLACK ground wire and grounded it to the frame to test it and the pump came on when I turned the key on.
Will grounding the black wire to the frame cause a fire hazard and what could I be missing?
Nov 20, 2009 at 12:26 AM
RACEFAN966
  • 5,029 POSTS
Looking over the wiring diagram for you truck the black wire needs to be grounded.
Nov 20, 2009 at 2:34 AM
