2000 Chevy S-10 fuel problem?
SLMCVEIGH
  • 2000 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 162,000 MILES
Trucks gas needle gets to 1/4 mark its hard to start. Now the truck runs for awhile then engine stalls. Fuel pump does turn on.
Tuesday, September 28th, 2010 AT 7:40 PM
HMAC300
  • 48,601 POSTS
Replace your fuel filter then check your fuel pressure. If it is low coming to the rail then replace the pump. If not ahave a pro check your fuel system as it can be other things like a regulator.
Wednesday, September 29th, 2010 AT 9:28 PM
