fuel cutoff switch
TILLER21579
Is there a fuel cutoff switch and if there is where is it located?
Sep 26, 2009 at 2:54 AM
BLUELIGHTNIN6
  • 16,542 POSTS
This car does not have a fuel cutoff sensor only Fords do. Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 1, 2009 at 12:54 PM
JEREGOT5
Engine Mechanical problem
1995 Chevy S-10 4 cyl Manual
where is the reset located on for the fuel pump
Jan 30, 2019 at 6:40 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump / oil pressure switch is located on right side of engine, behind alternator. if no power to pump, also check fuse and fuel pump relay.
TNR0788
1988 Chevy S-10 4 cyl Two Wheel Drive Manual
Hello, i have to remove my exhaust manifold and my fuel filter n it's hosing are in my way! Can you tell me where the fuel shut off valve is so i can remove the filter and have access to the manifold bolts?
INTERNETMECHANIC
  • 700 POSTS
Hi, there is no shut-off valve. After the vehicle sits overnight without the key being cycled or started, there shouldn't be much pressure if any. That doesn't mean fuel won't try to run out.
