2000 Chevy S-10 flasher
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISC1525
iam having truble with my turning signal. i change the bulbs and flasher and all the fuse's.and its still blinks fast.and only the right side that does it.and the right light get dim..can any one help me
May 8, 2008 at 6:44 AM
HARRY MURRAY
Have you checked if one light is out and if so maybe the wires going to it should be checked for continuity...you dont want to go the way of replacing the turn signal assembly....hard work
May 10, 2008 at 5:12 PM
