remove upper fan shroud and connections
remove air cleaner outlet resonator fasteners
remove resonator outlet duct
disconnect vaccuum brake booster hose at throttle body and disconnect crankcase vent hose from top of engine then remove air cleaner outlet resonator
next use 2 fan clutch wrenches
part number (j-41240) to remove fan and fan clutch as a assembly.
installation is opposite of removal
Jun 13, 2010 at 3:30 PM
