2000 Chevy S-10 Engine oil pressure and noise problems
157,000 MILES • 4 CYL • 2WD • MANUAL
HARLEY MIKE
when first started the engine sounds fine and the oil pressure is good. After the engine reaches operating temperature a clicking noise develops at the front of the engine towards the bottom. There is also a lose of oil pressure. The oil pressure increases with the RPM's and around 3200 RPM's the noise goes away
Feb 10, 2009 at 6:12 AM
  • 75,988 POSTS
Get the oil pressure check could mean an oil pump or engine bearings problem
Feb 10, 2009 at 6:15 AM
