2000 Chevy S-10 Engine noise--Vibrating/grinding between 25
2000 CHEVROLET S-10
114,547 MILES • 4 CYL • 2WD • AUTOMATIC
CASTEELE
Recently, my truck started making a vibrating/grinding/rattling/clattering noise, but only when going between 25-45 MPH. It makes the noise while cruising and accelerating, but not while decelerating. The best way I can describe it is that it is similar (but not exactly the same) as the sound my last car made when the catalytic converter needed to be replaced. But I do not think that is the case with my truck. It sounds almost like a bushing/cover is loose and grinding against something. Anyone have any thoughts on where I might start looking?
Thanks,
C. M.
Nov 12, 2008 at 11:34 AM
RHALL77
  • 3,361 POSTS
its hard to tell over the internet and not being able to hear it. have you looked to see if anything is loose.
Nov 13, 2008 at 10:53 AM
