2000 Chevy S-10 engine bogging
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
LISAFRRLL
My spouse purchased a truck from a fellow employee and was driving the truck home friday. Well on the way home it started bogging down and acting low on gas but he had just took it from empty to full moments before. Well I thought maybe it just needed some heet ran through so I had him do that. So he did. Well although he had to start and stop it the whole 56 miles home he made it. Well I told him to leave it home and let me look at it but he decided to change the fuel filter and try again so he took it to work and it took him 2 hours to drive the 56 miles to work. Well he got off and started home and only made it 20 miles. Then it wouldn't go over 20 mph. Then he parked it. Sunday morning he went to get it and it drove home fine. Then when he took it to work today now monday it is doing it again and now its even back firing. Not sure what the problem is.
Jul 26, 2010 at 3:22 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 26, 2010 at 3:38 PM
