2000 Chevy S-10 Dorman oil cooler lines
10,900 MILES • 6 CYL • 2WD • AUTOMATIC
RAYBIRD2112
I want to replace my oil cooler lines with the Dorman oil cooler lines. However, I notices that the connector to the radiator is different from the origional factory. What do I have to do to make the Dorman lines connect to my radiator properly?
Apr 11, 2009 at 9:04 AM
BLACKOP555
  • 10,386 POSTS
what kind of dorman lines are you putting on? take pictures is the best way for me to help you
Apr 11, 2009 at 10:51 AM
RAYBIRD2112
I cannot download pictures for some reason. However, my old line, that connects to the radiator has a nut and then a flare end on it and it snaps into the connector to the radiator and is held by a clip. The new hose end is different and only has a flared end on it and doesn't seem to fit all the way into the radiator connector like the old factory line. The new line also comes with a round plastic piece, that I assume takes place of the nut? Also, I don't know if there are supposed to be o-rings on the radiator connecting end too. Any help would be appreciated. Thanks.
Apr 11, 2009 at 12:06 PM
BLACKOP555
  • 10,386 POSTS
you can always cut the hose and put it on with a hose clamp. can you find your hoses online and get me a link to it?
Apr 11, 2009 at 1:24 PM
RAYBIRD2112
Well, I finally got it fixed. I just wasn't pushing the line into the radiator connector hard enough. I really had to force the top one with a lot of pressure. Finally it went. Thanks for the replies.
Apr 12, 2009 at 7:44 AM
BLACKOP555
  • 10,386 POSTS
that will do it!
Apr 12, 2009 at 9:30 AM
