2000 Chevy S-10 Chevy S10
102,000 MILES • 4 CYL • 2WD • MANUAL
GSKRAMER
I have a 2000 S10 (2 wheel dr/ 4 cyl) that is hard to shift. I purchased it off my son and he said it needed a new Slave Cylinder for the clutch. It is harder to shift in the last couple of weeks, and I would like to know 1- How do I know it needs one. and 2- How to install it.
Any and all information is appreciated.
Jan 7, 2009 at 2:57 AM
  • 110,248 POSTS
Hi:
Does the truck chatter or jump when you pull out?
Jan 15, 2009 at 12:26 PM
GSKRAMER
Not really. Shifting is forced. to the point I feel i am going to break the stick shift. Grinding is present about 50% of the shifts. Reverse is a two handed shift.
Jan 15, 2009 at 10:22 PM
  • 110,248 POSTS
It sounds like it needs replaced or you have a worn pressure plate that isn't disengaging the trans. Go with the cheapest and easiest first, the slave cylender.
Jan 16, 2009 at 12:22 AM
