Yes a tie rod can do that.
You can check your tie rod easily. Raise the vehicle with a jack and place jack stands under to support.
Then try to to move the tie rod up and down (from ball socket), if you can move it up and down, it's worn. You will be able to move it back and forth, it's normal.
I would also check other parts like
Ball Joints
Wheel bearings
Lug nuts
caliper bolts
rotors and loose brake pads.
And tire pressure.
SPONSORED LINKS
Wednesday, June 17th, 2009 AT 9:08 PM
