2000 Chevy S-10 cam sensor
17,400 MILES • 6 CYL • 4WD • MANUAL
TEDLINDBLOM
snap on scanner,,mt2500 scanner info, shows that cam sensor to crank sensor,, has diff of -14 degrees allthogh no code set ,,,, i suspect a worn out timing chain,,,am i correct?,,,,,in the snap-on parameter def. manuel,,, its call cam retard,,, thx
Nov 2, 2010 at 6:16 AM
JDL
  • 16,098 POSTS
My info shows this for cam retard adjustment. If you can't adjust,yes, you will have to look elsewhere. Did you try to adjust?
https://images.2carpros.com/forum/automotive_pictures/170934_cam_retard_adjustment_1.jpg
Nov 2, 2010 at 6:25 AM
