2000 Chevy S-10 brake lights
D. SAWYER
  • 2000 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 81,000 MILES
Both of my brake lights stopped working. I changed the bulbs but, still will not work.
Tuesday, November 18th, 2008 AT 8:55 PM
JDL
  • 16,098 POSTS
If you have a high mount brake lite, does it work? Usually the high mount brake lite is not wired through the the turn signal switch. The lower brake lites are wired through the turn signal switch.
If somebody steps on the brakes, do you have B+ and ground at the connector for the brake lites that are not functional?
If no brake lites are functional, you may have to check the brake lite switch and circuits.
Wednesday, November 19th, 2008 AT 2:47 PM
